jjrsmp12
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 30, 2004 - 1:36 pm: | |
1980 Eagle Model 10. Where do you position the jack to jack up the tag axle? Also, is this a true tag axle? It doesn't look like the axle extends from wheel to wheel. Thanks |
J.C. Barnett (Eagle)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 30, 2004 - 2:48 pm: | |
It is not a tag axle it is a bogie axle. It is located in front of the drive axle. |
jjrsmp12
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 30, 2004 - 3:07 pm: | |
After reading through some posts, I now understand that. Where do you jack it up? Mine shows a small portion of axle extending from the wheel, then it stops. |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 30, 2004 - 8:27 pm: | |
I just use a 20 ton bottle jack placed directly under the axle spindel. I guess I'm calling it correctly. You have to crawl behind the tire to place the jack at that position. David |
jjrsmp12
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, December 02, 2004 - 8:01 am: | |
I assume that is the correct place to jack? It looks like a 1 foot piece of axle and then stops. Correct? |
