Air Throttle Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » December 2004 » Air Throttle « Previous Next »
J.C.B. (Eagle)
Posted on Tuesday, December 07, 2004 - 1:53 pm:
Has anyone installed a Williams Air Throttle in a Eagle Model 10 with a DD 6V92TA?
I contacted Williams company and they suggested the following parts but were not sure if they would fit in the Eagle Model 10.
Throttle Pedal--WM453M & N series--Part #116731
I am concered about the angle of the pedal to the floor in the Eagle.
Throttle control cylinder--WM388105--Part #11788
Transmission Modulator---WM775B--Part #117830. I know this is the correct part for the tranny.
Thanks for any help you can give.
jimmci9 #2
Posted on Tuesday, December 07, 2004 - 7:21 pm:
i bought a new williams air throttle pedal and air slave cylinder from ronthebusnut.com also got a couple extra air line fiitings too... all for $208 plus shipping... best deal i've found... i put it on al old 671 on a tdh5105 gm transit... i had to make the bracket that mounts on the governor... but that took maybe an hour... btw... ive got a used air throtle and a used air cylinder, maybe te bracket... all for $150 if you want it... buy your own DOT plastic/nylon air line.... interested??? jimcat2@webtv.net
