Noisy roof! Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2001 » September 2001 » Noisy roof! « Previous Next »
jack Watts (24.4.255.65)
Posted on Friday, July 06, 2001 - 8:05 pm:
It's 90% outside and my eagle roof is bending and popping. I have just gutted it out and have taken the windows out. Is this normal for the roof to bow in some areas and sound off when it does? jack
Prather (63.66.58.198)
Posted on Wednesday, July 11, 2001 - 10:16 am:
If the structure is sound you should be able to remove everything, i.e. windows, siding, internal components without anything bending. So, somewhere you have a structural problem.
Prather
Karl crigger (152.163.204.83)
Posted on Tuesday, September 04, 2001 - 9:47 pm:
Jack
metal does that it is a lot easier for it toheat up with nothing around it dont worry a bout it it will quit when you insulate
Steve 80 Crown Atomic (205.188.192.178)
Posted on Saturday, September 08, 2001 - 5:03 am:
Sounds a lot like different thermal expansion between the frame and roof panels. Does your bus roof have a steel frame and aluminum panels? If so, you might try painting the roof white to keep it cooler and lessen the expansion, or perhaps replace aluminum panels with steel. I don't think insulation will solve this problem.
Steve
Scott Whitney (63.151.68.130)
Posted on Sunday, September 09, 2001 - 12:17 am:
I've got aluminum roof on steel ribs. A coat of super reflective white (KoolSeal etc.) paint may do wonders. I now also have a 12 foot long roof rack that provides perpetual shade for 1/3 of my bus. Helps a lot too.
Scott
