SMOKE IN THE AIR Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » December 2004 » SMOKE IN THE AIR « Previous Next »
DAVID HEAD (Chuck)
Posted on Tuesday, December 28, 2004 - 7:30 pm:
WHAT CAUSES THE ENGINE TO SMOKE WHEN I PULL AWAY FROM A STOP OR WHEN I REALLY POUND ON THE ACCELERATOR.THE CLOCK SAYS IT HAS 450000 MILES ON IT
Geoff (Geoff)
Posted on Tuesday, December 28, 2004 - 7:41 pm:
Overfueling. This can be controlled by your foot or by a throttle delay.
John that newguy
Posted on Tuesday, December 28, 2004 - 7:44 pm:
Too much fuel getting dumped into the engine due to:
1. Larger injectors than are called for
2. Poor rack adjustment
3. A heavy right foot that's too used to automobile driving
It's usually #3
Posted on Wednesday, December 29, 2004 - 5:13 am:
With 450,000 miles it could be low compression from shot rings ,
or rusted & pitted cylinder walls from too much sitting with out preservation.
The COLOR if the smoke would help the diagnosis, also miles per gallon of lube oil.
Posted on Wednesday, December 29, 2004 - 9:57 am:
If it was bad rings or bad cylinder walls, it would smoke all the time not just when pulling away from a stop sign.
TWO DOGS
Posted on Wednesday, December 29, 2004 - 10:19 am:
you are just giving it more fuel than it can burn...instead of instant acceleration...a diesel needs to be raised in r.p. m. more slowly...if you see a hill,start building your speed BEFORE you get to it
