Door closer on mci 9 Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » February 2005 » Door closer on mci 9 « Previous Next »
Carl Olson (Carls_mci_9)
Posted on Tuesday, February 01, 2005 - 10:10 am:
Has anybody removed the door closer handle on mci 9? Do tuo use the air closer to keep door shut?
marc schlabach
Posted on Tuesday, February 01, 2005 - 5:07 pm:
I removed the rod and all. I still use the air lock. I also put a locking latch on. It works great.
marc schlabach
Posted on Tuesday, February 01, 2005 - 5:10 pm:
The air lock doesn't work after you sit a while and your air leaks out. You need a lock to secure it when your'e out of the coach. marc
dana dutkowski (Dana23)
Posted on Tuesday, February 01, 2005 - 6:52 pm:
i put a house dead bolt lock in it can be done but takes a little time think there a posting on how to do it but dont remember were i seen it maybe someone here does
Stan
Posted on Tuesday, February 01, 2005 - 8:44 pm:
It saves a lot of work if you put the deadbolt in the opposite way to normal. Buy a long throw deadbolt (about 6" long) and mount in the door post with the locking mechanism to the rear of the post. Then you just have to make the recess for the bolt in the door edge.
Michael Lewis (Puffbus)
Posted on Wednesday, February 02, 2005 - 1:56 pm:
I spent some time in a nearby bus lot a couple weeks ago and one of the things I noticed is how clean and nice the stock MCI deadbolt is. After seeing a couple, I would not even try to fit a household deadbolt. The MCI units use a SS bolt about 3/8" square, and the face of the lock fits almost flush. I bet Luke has these.
I too, removed all the door closing hardware including the handle. Makes for a much cleaner dash. I kept the air lock for over the road use. It's amazing how well that claw sucks in the door!
Michael
Posted on Thursday, February 03, 2005 - 6:00 am:
For any coach (cept those with solid plastic doors)
http://users.cwnet.com/~thall/FAST%20FRED.htm
Works for me,
