mclough
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 01, 2005 - 5:50 pm: | |
If you go with a house hold refridgerator, how would you bolt down to secure it in place? |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 01, 2005 - 5:56 pm: | |
i"x1" angle iron pop riveted to outer hull & fastned to wall |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 01, 2005 - 6:00 pm: | |
also...you need a latch to keep the door from coming open when you turn a corner...available at any r.v. place |
Richard4905
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 01, 2005 - 6:08 pm: | |
On my GMC4905 I used a house refidg. Took off the screw in levelers installed bolts with nuts straight down A second nut with washer drilled holes in floor set refg. in place & bolted it down using second nut above floor to adjust level. Worked great Hope this helps Richard |
petere
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 01, 2005 - 6:17 pm: | |
Pop Rivits! ....no way! I would think 4 - 1/4" screws (with washers and nuts) as a minimum |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 01, 2005 - 6:21 pm: | |
Two Dogs got it right the first time, only I would use 2" angle instead of 1" and use LOTS of rivets on the reefer body and LOTS of bolts into and thru the floor. "Lets see....a 150 pound icebox decelerating at 10 gravities during a head-on wreck (quite user survivable really) results in...WOW!!, a lot of force!! Plus...don't forget about the doors! |
jimmci9 #2
i use a 1" nylon strap... i have eye-bolts in the floor, wall.. ceiling....takes about 2 minutes... |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 01, 2005 - 6:32 pm: | |
I'll see if I@N feels like posting a picture...my refer is SOLID |
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 03, 2005 - 3:18 pm: | |
By the request of Mr. Dogs, a photo of his reefer securement. Uh, I'm not sure which way is up, so hope this is right. |
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 03, 2005 - 3:27 pm: | |
that is correct Chuck....brackets are on both sides...halfway up...it has not moved since instalation.. |
John Gerard
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 17, 2005 - 5:26 pm: | |
i am looking for comments on using a Banks system in a 8.1 vortec chevy engine. any experience on installation, power,gas milage, etc would be appreciated. |
