1980 Eagle Torsion Bars Continued Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » February 2005 » 1980 Eagle Torsion Bars Continued « Previous Next »
jjrsmp12
Posted on Tuesday, February 08, 2005 - 8:48 am:
Well, I took the coach into a local bus repar facility. They said no adjust ment left on torsion bars on one side and 5% on the other side. They estimated 150 hrs @ $80/hr for installation of torsion bars. That's 12K for labor + the parts. My question is this... If the torsion bars are fine and there is no adjustment left, can't they turn the bols somehow? I doubt every one of the torsion bars is bad as it drives awesome. Any suggestions? I'm going to contact jefferson bus today and also Luke.
Sonnie Gray (Catskinner)
Posted on Tuesday, February 08, 2005 - 9:01 am:
The torsion bars can be re-indexed, if they are
in good condition. Also Jefferson may have
longer adjustment bolts available for minor
adjustments. I don't remember if Norris at
Jefferson told me this or if it was someone else.
Or just about any good machine shop could fab-
ricate longer adjustment bolts.
Goodluck!
Catskinner!
Sonnie Gray
Pottsboro, Texas
72 0/5 Eagle 3406 Cat
have no idea what you want to hear... I have told you my opinion...it's just STUCK
Posted on Tuesday, February 08, 2005 - 2:03 pm:
Let us know what Jefferson tells you.
David
Ken Turner (Pipesusmc)
Posted on Wednesday, February 09, 2005 - 2:00 pm:
jjrsmp12
http://members.tripod.com/Pipesusmc/Kaykay.htm
If you like, send me an email and I will give you my PH # ( near Seattle )
I might be able to help with some suggestions.
Also tell me the area where you live
Posted on Wednesday, February 09, 2005 - 7:07 pm:
I had my bogies re-indexed many years ago. I do not remember the cost, but it was just a few hours labor. As I recall, Remove the wheels, remove the adjuster, pull out the torsion bar and turn it one slot and re-install. Something like a drive shaft spline IIRC.
Posted on Thursday, February 10, 2005 - 1:49 pm:
Richard,
He is out of thread on the drives. At least that is the idea I get from his pictures in his previous post farther down the board.
David
jjrsmp12
Posted on Thursday, February 10, 2005 - 3:48 pm:
I am taking it to a place in Alliance, Ohio this weekend. A guy there was referenced by Norris at Jefferson. The name is Buddy and he used to work for Eagle. Buddy said they will look at it and hopefully they will have enough knowledge about my girl... I'll keep you posted. Thanks
Posted on Thursday, February 10, 2005 - 7:04 pm:
When you re-index the spline of the bogie, you start out with full adjustment again. The torsion bar must be removed from the splined socket and turned one notch. about 30 degrees IIRC.
jjrsmp12
Posted on Saturday, February 12, 2005 - 8:56 pm:
Just got back from Alliance Ohio this evening. Former Eagle mechanic worked on the bus all day. Good news, all torsion bars are good and the drivers side drive-axle bar only needs adjusted. I was glad to hear it. I will pick her up next weekend and keep you posted. Bus weighed in at 32,000 lbs without water tank. Bogie passenger was 2500 lb and drivers was 3000lb. I'll keep you posted. Thanks
Posted on Sunday, February 13, 2005 - 2:01 pm:
JJrsmp.
I checked my eagle manual and each bogie should carry 15% of the load. 32000 X.15 =4800 per bogie on your application. You need to reindex each side. Looks like driver's side needs at least 3 splines and passenger needs 4 splines.
Each spline is 500 lbs.
That seems like a lot. My coach only needed 2 splines each side and I'm at 36K lbs wet on a converted coach.
Talk it over with your mechanic and take a look at the shop manual together.
David
jjrsmp12
Posted on Sunday, February 13, 2005 - 6:50 pm:
Good point. He used the guage on the jack for each bogie after leveling the coach. We read 1300psi for passenger(2600 lbs) and then 15--psi for drivers(3000 lbs). This is before adjusting the drivers side rear torsion bar. I saw a section of the manual which states "each bogie wheel carries about 11% of the total coach weight"). I also saw the 15% statement. Anyways, 11% of 32K is 3520 lbs. So I see 1 spline for drivers and 2 splines passenger? I'll talk with the mechanic on Monday. I'll keep you posted. Thanks
jjrsmp12
Posted on Sunday, February 13, 2005 - 6:58 pm:
Also, I assume the weight on the bogies will change after adjusting the torsion bar, correct?
Posted on Tuesday, February 15, 2005 - 2:10 pm:
jjrsmp,
You're right about that 11% and 15% discrepency. There is a picture diagram that shows the wheel loadings with percentages. They add to 100%. Without going out and rereading the book, I think I used the 15% scale because the diagram added up to 100% coach weight.
Keep in mind that when you increase the load on the bogies the drives will lighten and the front (a small amount) I don't remember if you told us if you are converted or empty???? At 32K lbs, I assume empty. All this will change when you convert.
In my coach for example, I have my genny in the front bay. So extra weight on the front, but about 700lbs below front GAWR as per mfg data plate.
You can tinker with this now, but I'd just get it up to ride height, do the conversion, then do it again. Watch and learn. You can do it yourself next time. It's grunt work and tedious, but can be done on your own.
David Anderson
