Looking for used caliper for S1700 IHC Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » February 2005 » Looking for used caliper for S1700 IHC « Previous Next »
Lee Harrison
Posted on Thursday, February 10, 2005 - 12:14 pm:
I purchased an IHC S1700 school bus 2 years ago, 7.3 L, 5 sp manual, diesel. I have 2 questions. 1) Does anyone know where I might locate a used disc brake caliper for it? Also, I have a hard time getting it up to 50 mph, and I was wondering how to determine if the speed is governed, and how to disable it, if it is? btw, it has 90,000 miles, and starts easily, and does not smoke.
Posted on Thursday, February 10, 2005 - 12:43 pm:
would imagine it IS goverened...a diesel shop could turn it up a bit...but...school buses are not really geared for the highway & don't have enough power to make it practical to change rear-end gears..AND...new gears are 2000.00
Nick Morris (Nick3751)
Posted on Thursday, February 10, 2005 - 10:38 pm:
have the goverer turned up and put a Banks system on it. that will over come any power trouble you may have pretty well.
Johnny
Posted on Saturday, February 12, 2005 - 12:16 am:
That NA 7.3 IDI should run 65 easily, unless the axle ratio is something like 6.14:1 (which it might well be). What RPM is it turning at 50 in high gear? IIRC, the 7.3 IDI is governed around 2800-3000RPM in Internationals.
New gears might be $2000, but a take-out rear axle from a highway-geared truck isn't. My B-700 has probably been regeared, since most gas-engine Ford schoolies I've seen top out around 60-62MPH. Mine will run 70 (I cruise at 65), & isn't even spinning 3000RPM. I have a rebuilt 460 with ~350HP, but even a stock 180-200HP 370 should have enough power for 60-65MPH.
As for the brake caliper, check a heavy truck junkyard...but I suggest just getting rebuilt calipers, rather than using one from a junkyard.
If you want more power, I suggest an ATS turbo. I have one on my 7.3-powered 1992 Ford F-350, & it's untouched with 360,000 hard miles.
Lee Harrison
Posted on Wednesday, February 16, 2005 - 11:20 am:
Thanks for all the suggestions. I don't know what the RPMs are since there is no guage. I might just try adjusting a screw on the throttle linkage where it connects to a device (injector pump?) and see if that makes a noticable difference. Since I am only using the bus to move my belongings from NJ to TN I don't want to invest any more than the $1600 I paid for it. I will most likely sell it when I am done with it. I did get a rebuilt caliper, replaced the old one, and bled it, but I think it needs the other side bled as well.
