bill lee
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, February 20, 2005 - 1:58 pm: | |
I have a 1973 flxible bus with air bags. Is there anyway to stop the sway? I have replaced the air bags but it still sways bad. Is there someone in the phoenix area that can do that? thanks bill lee 602 321 9378 |
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, February 20, 2005 - 2:02 pm: | |
very possible modifacation...two heim-ends & a i" bar...some welding...do you know any hot rodders in your area............. |
Bill Gerrie
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, February 21, 2005 - 1:19 am: | |
Bill Are you sure that your shocks are okay. I had a bad set of Delcos right from MCI and when i got on the highway I just about lost it when It started to do a side to side roll after an uneven section in the roadway. I took them off and you could move them in and out by hand very easily. When I went back to MCI the whole shipment was bad. I replaced them with Gabriels and haven't had a problem since. Cheaper to. You might want to see if your sway bar is broken inside of the rubber mounts. I have seen this also and it is hard to detect unless you undo one of the links and try to move the bar. Something to check. Bill |
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 06, 2005 - 12:44 am: | |
Bill, the Gabriel adjustable shocks are something. On our coach, they are smaller than stock, but they really dampen any motion. We had bought brand new standard Gabriels, but they were noisy and did not have good control. The adjustables took care of both problems. We have a GM, so I can't tell you if Gabriel makes some that fit your Flxible, but it's sure worth checking on. For what it's worth. Tom Caffrey PD4106-2576 Suncatcher |
