captain ron (Captain_ron)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, February 21, 2005 - 4:41 pm: | |
I had exactly $518.00 dollars in my pocket when I went to pick up my bus. I swear on a stack of bibles my bill was $518.00 dollars. but I"m up and running and charging. I bought a new circuit board but it was not the right one it just let the voltage keep climbing so I put the old one back in and "PRESTO" it worked. but first we had to change the wiring of the alternator. the newer alternators are field 1 to pos. post on alternater I had to take that strap off and put my field wire from volt reg. there, then ground the other field to the case and again "PRESTO". SO MABEE NO MORE WHINING FOR A WHILE. The clicking in the panel to my left is still there but I believe it is the horn relay cause it only clicks when I move the wheel and that horn doesn't work. |
truthhunter@shaw.ca
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, February 21, 2005 - 5:03 pm: | |
Next time try lioning your wallet with lead. Doctors aren't the onlyone's that use x-ray machines ya,no. |
Robert Wood (Bobwoodsocal)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, February 21, 2005 - 6:06 pm: | |
Hehehe. Glad you are up and running again Ron, Bob |
Johnny
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, February 21, 2005 - 7:06 pm: | |
Hmm...maybe next time, have about $25 in the wallet? |
Sojourner (Jjimage)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, February 21, 2005 - 8:57 pm: | |
Good that you are making progress. Horn wire could be partly grounding (bare spot) to steering column to energize relay. Maybe trace the “horn button” wire so you disconnect until have time to replace with new. FWIW Sojourn for Christ, Jerry |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 22, 2005 - 9:17 am: | |
GO SOUTH CRYBABY ! ! |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 22, 2005 - 11:06 am: | |
and change your header back to CAPTAIN CRYBABY.... |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 22, 2005 - 11:42 am: | |
Change of plans: I'm going to Texas to spend the rest of the winter with my long lost dad Twodogs. |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 22, 2005 - 12:38 pm: | |
NOOOOOOOOOOOOOOOOOOOOOOOOOOoooooooooooooooooooooo |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 22, 2005 - 2:25 pm: | |
HAHAHHAHAHAHAHA |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 22, 2005 - 3:48 pm: | |
I'm hurt. just send money then |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 22, 2005 - 4:10 pm: | |
o.k.------just hold your breath till it gets there |
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 23, 2005 - 4:28 pm: | |
I'm turning blue |
