jjrsmp12
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, February 27, 2005 - 11:37 am: | |
I am fixing some stray wiring in the rear of the bus. I need to know, are the top 2 lights of the rear of an eagle brake lights only? OR do they double as tail lights and when brakes applied, the 2nd bulb activates? Also, there are 4 red lights below the bumper area. Are these tailights only? Thanks |
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, February 27, 2005 - 11:47 am: | |
I have an 05 Eagle....might be different....3 red lights on each side...middle one is turn signal...top & bottom are marker |
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, February 27, 2005 - 6:22 pm: | |
by the way...I changed all of mine....all are marker now & have 12 l.e.d.'s inside each tailight that only work for brake & turn signal |
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, February 27, 2005 - 8:05 pm: | |
My 80 Eagle 10 had two single element bulbs under each reflector. They were brake lights only. I believe the clearance lights were the same configuration. Anyhow, I took out the light assemblies and replaced the single element sockets with dual element sockets. I then re-wired so that I had two brake lights on each side and two clearance lights on each side. Made a lot of difference in the visibility of the bus. But what made the biggest difference, and what I strongly urge every Eagle owner to do, I lined the interior of all the plastic holders with aluminum foil tape. Including the back up lights. It does not matter if there are a lot of wrinkles. It is really unbelievable the difference that makes. Try it, I guarantee that you will like it. Richard |
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, February 27, 2005 - 8:49 pm: | |
I did the same...with stainless steel tape...available at home depo,in the plumbing dept. |
Ethan Tuttle (Mrert)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, February 27, 2005 - 9:53 pm: | |
On my 82 model 10 the top two lights are brake lights only. |
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, February 28, 2005 - 9:27 am: | |
Ethan, mine were also originally. I replaced the lamp holders with two element holders therby converting them to marker as well as brake lights. Richard |
