Bob Baldwin (Bob4106)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, February 28, 2005 - 3:41 pm: | |
Hi all I know some of you have not heard from me since I lost my wife. But I"m starting to get back in to the bus. I order and recivied my new peninsula windows for my 4106. I got the drivers and passenger or door window that open and have screens. And I got the glass and new rubber for the "D" windows. Installed then and very happy with them. They where easy to install and the windows are great. I think Peninsula Glass Company are good people to deal with. Now my plains are to up the water and gray water tanks up to 100 gallons. 40 gallons just don't get it for me. This is just me 2 cents and hope every one is doing fine |
Brian Brown (Fishbowlbrian)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, February 28, 2005 - 4:12 pm: | |
Hope you're doing all right, Bob. If I might ask, how much were your windows? I just got a new '06 myself and wouldn't mind upgrading some of the windows to dual pane w/ screens. Brian Brown Longmont, CO http://www.browncowpro.com/bus/4106/photos.htm |
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, February 28, 2005 - 9:04 pm: | |
I got the drivers and door - passenger side. And the two "D" windows and new seals shipped to North carolina for $750.00 total |
Sojourner (Jjimage)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 01, 2005 - 12:33 am: | |
Hi Bob, Sorry about lost your wife. Good youre back in here. Information of durable RV tank; Dura-Cast Products Inc south of Lake Wales, Fl http://www.duracast.com/content/pdfs/marinebroc.pdf Ardemco south of LA, Ca near Huntington Beach. http://www.ardemco.com/ardemco.asp?uid=5505 Whatever way you choose, I suggest get heavy duty type have Ό thick Rotomolded Polyethylene. Time save and trouble free. Rotomold mean a large rotating rectangle or square steel drum spinning about 30 rpm with hot liquid Polyethylene coating inside drum of your size. No weld joint to crack. They will install for free limited amount of spin-weld to your desirer location. Suggest installing 4 drain at both end and 2 vent & toilet fitting on top plus 4 pc of ½ or 3/4 fitting for both end bottom & top. Can always plug the unused ones then go back to spin-weld more. Water tank, at least one 2 vent fitting on top and your of smaller choice fittings any where to your desire. Reason for 2 for vent pipe for water is while you fill with city pressure (High-flow rate) to avoid chance of siphon out and possible collapse tank. It has happen from another board. Large 2 is enough to allow air pass over flow inside of pipe. Or you can use ½ or Ύ vent & add a Stop-vent near by (another small fitting) to allow air in but not out. There no glue to stick to Polyethylene but can heat weld to it. If want to make your own Fiberglas tank; http://www.boatus.com/goodoldboat/sanitation.htm Fiberglass will take must of your time to make. FWIW Keep looking UP! Sojourn for Christ, Jerry |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 01, 2005 - 12:42 am: | |
Bob - nice to hear from you - good luck - happy bussin - Niles |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 01, 2005 - 2:56 pm: | |
Thanks Jerry thats really helpful. And it's so nice to know that you all have been a big help on my bus converton and thanks again |
