FAST FRED (63.208.84.117)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 30, 2001 - 7:20 am: | |
IF the same coolant has been in your coach for a bunch of years its long past time to discard it. OR if you just got your new baby home , before ripping the interior to shreads , order DA Book , and begin doing the normal maint that your coach requires. The coolant {antifreez} in a coach is totally different ftom whats in an automobile. The coolant in a DIESEL will have SCA { suplimentary cooling addatives} . This stuff coats every part with a slime that is very important. AS a diesel fires the cylinder walls ring like a bell, this causes liquid next to the cylinder wall to cavitate , air bubbles come out , caused by the sudden lowering of pressure. The SCA holds the cavitation a tiny distance from the cylinder walls , stoping the destructive cavitation from eating the cylinder walls from the outside in. This SCA wears out , OR can get too concentrated , and since its everywhere in the cooling system can easily cause overheating. SO you should at least flush the system, cleaners can help ,too. You should try flushing {cheap} first. Drain entire system , refill with ONLY clean water, run engine ON ROAD!!! till warm , operate heaters , defrosters ect, go home and drain thru all {theres a bunch} of outlets. DO this at least 3 times ! You will not loose much cylinder walls running with no SCA if you dont lug the engine, while flushing. Disconnect a hose {have spare ready , hose welds itself to the engine in time} and feel inside of hose and block. IF its relativly clean of slime , and water has been real clean on draining , its time for a mix of antifreze and distilled water. 50/50% is usual mix , but you can go as low as 35 % antifreez and still get benifits of SCA. I only buy the coolant for a DD at the DD store. Penny wise and pound foolish, doesnt help on a $10,000 engine. They will also have a kit ($10.00 or so} for checking the state of the required SCA every 6 months . Da Book has procedure for venting air from any heaters or defrosters and can show you all the many drain points. IF you need a 2 part cleaner the DD guy has good stuff for about $50 that will do a couple of coaches. Flush even more if you use the 2 part cleaner. The flush procedure should be done at least every 3 years, as the antifreez also has many other chemicals in the additive package that gets used up. FAST FRED |
S Cole (24.4.252.6)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 14, 2001 - 9:53 am: | |
sorry, I'm new at this. What is "Da Book"? Thanks, Sam |
Al (205.175.225.22)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 14, 2001 - 10:19 am: | |
Sam: When you see a mention of "Da Book", that means the maintenance manual for your particular vehicle. |
s cole (24.4.252.6)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, August 18, 2001 - 4:11 pm: | |
Thanks! |
