Jacking up Bus Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2001 » December 2001 » Jacking up Bus « Previous Next »
William Winesette (Bwinesette) (63.25.74.223)
Posted on Sunday, December 16, 2001 - 11:32 pm:
I have a 1984 Prevost and I need to do some work under the bus. Where do I place the jacks and stands to safely work?
Bill
Jim Ashworth (Jimnh) (172.164.148.190)
Posted on Monday, December 17, 2001 - 10:40 am:
The Prevost book will have the info. If you don't have the book, the following is GENERAL information. Use it at your own risk since it is based on Prevost info for later model XL's.
Jacking point for the front is within the center 30" or so along the back of the spare tire compartment or the front of the front baggage bay. Rear jacking points are just behind the tag axle on the engine mounting rails. Easiest thing to do for work under the bus is to run it up on blocks. Use a 8"x10" timber of hemlock or similar and taper the end to drive up. Alternative is several layers of 3/4" plywood screwed together to look like a set of ramps. It is difficult to run both ends of a converted coach up on blocks due to the weight. One end at a time works pretty well.
Be safe.
Jim
FAST FRED (209.26.87.47)
Posted on Monday, December 17, 2001 - 2:26 pm:
AFTER you figgure out how and where to jack the bus ,
why not PAINT the spots
so the fellow at O'dark 30
who never even saw a bus in his life ,
that came to change your flat ,
Knows where to stick the air jack?
Might save some holes in the floor.
William Winesette (Bwinesette) (67.211.69.78)
Posted on Monday, December 17, 2001 - 7:10 pm:
Thank you for your advice this was just what I was looking for.
R.C.Bishop (128.123.88.26)
Posted on Monday, December 17, 2001 - 10:39 pm:
Jim,......My Crown books do not contain that information. Pages seem to be missing on Chassis. Is there usually a "point" before or behind a wheel that would be a jacking point, or would that probably differ from bus to bus? What about blocking axles? Ideas?
Thanx.
Jim Ashworth (Jimnh) (172.134.232.72)
Posted on Tuesday, December 18, 2001 - 8:06 am:
Crown's are totally out of my realm of experience. MCI & Prevost I'm ok with. Hopefully, someone else knows the Crown jacking points.
Jim
Steve Fessenden (63.27.88.151)
Posted on Tuesday, December 18, 2001 - 1:08 pm:
Speaking of tire changes on Prevosts with tag axle lift switches. When I had my tires changed they had me pull one drive wheel at a time up on two 2 inch thick boards to raise the tags wheels on that side. To raise the drive wheel s we raised a tag put boards under it and lowered the tag to raise the drive wheel.
William Winesette (Bwinesette) (67.211.112.188)
Posted on Tuesday, December 18, 2001 - 7:42 pm:
Thanks guys. I am building ramps this week.
Bill
