Help trans linkage problem Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2001 » September 2001 » Help trans linkage problem « Previous Next »
bob m. (152.163.201.82)
Posted on Saturday, September 01, 2001 - 7:59 pm:
i cant get my transmission to shift out of third using the shift lever i have traced the problem to the 3-4 shifting rod somewhere above the rear end. forward of the rear end it come out of the bulkhead and has a fiber type cover over it. both the cover and the rod move back and forth when i operate the shift lever. behind the rear end the rod barely moves where it enters the engine compartment and the covering moves 2 inches in either direction when the shift lever goes from third to fourth and back. i can't see above the rear end itself i wonder if there is a coupling on the shift rod that has come loose or is the rod itself broken?
califbob (209.179.251.228)
Posted on Sunday, September 02, 2001 - 12:01 am:
may be able to help if I knew what kind of bus you have.
bob
