26/11/24 - 15:44 PM
Author Topic: Reverse switch on 4104  (Read 155 times)
Offline frank4104
  • Member
« on: September 15, 2024, 08:12:53 PM »
I had trouble getting the 4104 in reverse last week. I have had the bus for 20 years and it has happened before, but has not happened in years.
Anybody know the fix ?
Also I read that it can be done in the engine bay, but I don't know how to do it. .
Any thoughts
Thanks
Frank and Wanda
Ormond Beach Fl.
PD 4104-2729
Offline dtcerrato
  • Member
Re: Reverse switch on 4104
« Reply #1 on: September 16, 2024, 10:08:59 AM »
Frank here's a photo of the reverse solenoid on our 4104s
When you put it in 1st gear and hold the reverse switch on the dash panel and simultaneously move the shifter into 2nd gear the activated solenoid would be moving the shift into reverse. Is your solenoid pulling like it should while moving from 1st to 2nd gear while simultaneously holding the reverse dash switch? If not check the wiring going to the solenoid. That is where I'd start. It could be other things like your linkage but best to start with the simple things, Notice the extended rod on the solenoid arm that extends beyond where the connecting pin to the solenoid pull plunger is, if there is no electromagnetic pull from the solenoid during reverse shift use the extended rod on the arm to manually push the solenoid forward by hand while shifting from 1st to 2nd. If the solenoid is the problem that will get you in reverse gear. HTH
Dan & Sandy
North Central Florida
PD4104-129 since 1979
Toad: 2009 Jeep GC Limited 4X4 5.7L Hemi
Offline dtcerrato
  • Member
« Reply #2 on: September 16, 2024, 10:14:22 AM »
I'm not able to post the photo on here, email or text I can send it to?
Dan & Sandy
Offline frank4104
  • Member
« Reply #3 on: September 16, 2024, 05:56:04 PM »
I sent you an e-mail Dan..
Frank and Wanda
Ormond Beach Fl.
PD 4104-2729
Offline dtcerrato
  • Member
« Reply #4 on: September 16, 2024, 08:15:27 PM »
I didn't receive it.
Dtcerrato@aol.com
Dan & Sandy
