23/11/24 - 05:44 AM
Author Topic: Motor Oil for 671 Detroit Diesel  (Read 26984 times)
Offline FAST FRED
  • Member
Re: Motor Oil for 671 Detroit Diesel
« Reply #15 on: November 17, 2012, 07:57:36 AM »
SAE30 in all 71 Series DD engines
SAE 30 was the DD recommendation for a long time , but the eventually found better life at 40.
Hound would change (rebuild) engines mostly by time , although the goal was to swop em out at about 200,000 miles.
A friend was a wrench in Miami , way back, and claimed a 4106 swop would be done by midnight by the night shift. Only realigning the Air Cond was left , as that took a long time.
 This was back when 5lbs of freon would be added each week , and was considered a tight system!
They started with the replacement engine and tranny already mounted in its cradle.
Thank goodness for Cannon Plugs!
Offline TedCalvert
  • Member
« Reply #16 on: November 17, 2012, 10:21:39 AM »
Don't kill me for highjacking this thread, but I can't figure out how to start a new one!  It is about oil, Dexron for '87 leMirage power steering. Which Dexron?
I gotta get da book.
Thanks.
Ted
Offline eagle19952
  • Member
  • Donald P H.
« Reply #17 on: November 17, 2012, 12:59:06 PM »
http://busnut.com/forum/index.php?action=post;board=2.0
To start a new thread you can clic the words above
BUT at the top of the "Contents" page of topics called THE BOARD there is a blue file tab like a folder, on the left of it will be the NEW TOPIC clik spot..
HTH hope that helps.
I think the old Dexron will work.
I have used a lot of 0w30 synthetic in a lot of GM automotive power steering systems but i am not sure about yours.
1978 Model 05 Eagle w/Torsilastic Suspension,8V71 NA, DDAllison on 24.5's 12kw Kubota.
Wants Paint :)
Previously owned by Wee Willie Ent.
Offline TedCalvert
  • Member
« Reply #18 on: November 17, 2012, 05:14:59 PM »
Thank you.
