TOPICS => THE BOARD => Topic started by: jackhartjr on May 16, 2014, 05:39:32 PM
Title: Deka AGM batteries?
Post by: jackhartjr on May 16, 2014, 05:39:32 PM
Need 10 Deka 8A31 batteries for the APU in my truck! Seem to be running in the $230.00 to $250.00 range! Anyone out here know a good source for them, maybe a little less costly!?
 Thanks
Jack
Title: Re: Deka AGM batteries?
Post by: luvrbus on May 16, 2014, 06:02:51 PM
About the only way is buy the flooded batteries for 100 bucks each,but I did see the Duracell AGM made by East Penn same as the Dekas for 166 bucks at Sams or Costco I don't remember which and thought it was a good price for a 31 AGM American made battery
Post by: eagle19952 on May 16, 2014, 10:54:10 PM
where are you located ?
the distributor in Fort Myers FL. treated me very good.
a distributor can have the factory ship seconds...they are cosmetic blems only.
they can be very discounted.
ps. I think all Deka regional distributors sell to the public
PSS, I just checked, I paid $73.64 for a grp 31AGM and $ 230.00 for 2 4D's.AGM
Post by: jackhartjr on May 17, 2014, 08:33:02 PM
Thanks a ton! Do you have a contact for the Fort Myers distributor?
I only go to Fort Myers every week!
Jack
Post by: eagle19952 on May 17, 2014, 10:53:26 PM
Jack
Just walk in....its off Alico Road, going west off 75, turn Left on Gator and Right on Supply down about a block and a half, it will be on your left, go in the lot (has a chain link fence) door in the middle (office) batteries around back, they let me go back to look.. and they load tested the batteries I bought, they all loaded at least 10-15 % over spec...but...I would call ahead if I wanted the amount of batteries that I think you want. They don't stock mountains of seconds...
Taylor & Crowe Battery Co Inc
7991 Supply Dr  Fort Myers
239-949-0333
https://www.google.com/maps/place/7991+Supply+Dr/@26.5001773,-81.8134638,14z/data=!4m2!3m1!1s0x88db144b185da345:0x90a6cf2488da5864 (https://www.google.com/maps/place/7991+Supply+Dr/@26.5001773,-81.8134638,14z/data=!4m2!3m1!1s0x88db144b185da345:0x90a6cf2488da5864)
Post by: eagle19952 on May 17, 2014, 11:06:46 PM
PS you might just decide for price that 4 4D's would be better and cheaper..
Post by: TomC on May 18, 2014, 01:22:47 AM
If you're using that many batteries, you might consider going with the L16 AGM battery. I know that the Lifeline L16 is 400amp/hrs. I'm using 4 of them (6v each) for 800amp/hr at 12vdc. The bigger the batteries and the less batteries you use the better. Harder to keep multiple batteries balanced. Good Luck, TomC
Post by: FAST FRED on May 18, 2014, 07:21:53 AM
WHY?
Do the batts provide air cond with the APU shut down?
Post by: eagle19952 on May 18, 2014, 02:30:38 PM
Taylor and Crowe carries other lines and will know all the options to consider. I am sure they can help you decide.
Post by: jackhartjr on May 18, 2014, 04:51:50 PM
Fred, it is a battery operated APU. There is a charger/inverter that steps it to 120-v to power a 10,000 btu a/c. That way I don't have to idle the truck at one gallon per hour. Those 10 particular batteries should give me 10 hours run time. There is a 320 amp alternator to charge back during the day!
During the summer it's not uncommon to idle 50 hours! That's $200.00 a week savings, not to mention the reduced wear and tear on the engine!
Hope that helped.
Jack
Post by: FAST FRED on May 19, 2014, 07:30:51 AM
You need the AGM , as they have the ability to deep cycle deeper than WLA (wet lead acid) and far more important they can accept a far higher rate of charge during the bulk charge stage.
As the recharge tine is limited only the AGM will do it.
Soon perhaps the electric car batts LI will be useful, but its still years away , and they still suffere from problems , ask Boeing.
Good luck in your hunt for a good price .Some dealers will give a better price for an all cash deal.
Post by: TomC on May 20, 2014, 12:09:43 PM
Jack-10 size 31 batteries will be over 700lbs worth! I sell Freightliner trucks, and also with my 21 years past of driving over the road, the best is to install a Diesel engine powered APU. The only one that is California approved with a Diesel Particulate Filter is the ThermoKing Tripac APU. It ties into your A/C system and has an inverter. The APU weighs about 500lbs and burns maybe as much as a quart an hour. With sitting over the weekend and such, batteries just don't work. I had a 6.5 Onan Emerald III commercial gasoline on my truck that I got over 12,000hrs before replacing. While it burned close to a gallon an hour, was still cheaper then running the big engine. Battery powered APU's on trucks just plainly don't have the power for long enough for someone running the road. Good Luck, TomC
Post by: FAST FRED on May 21, 2014, 06:57:33 AM
While there is no FREE LUNCH , charging a huge batt set with the vehicles existing alt will still be cheaper than a second dedicated noisemaker that has to be purchased , maintained and fed.
1/4 GPH is a gallon every 4 hours or perhaps $12. of fuel every hot night.
The AGM should last at least 2-3 years and can run one of the new DC air cond .for down times.
The math will show which is easier and cheaper for the usual operation cycles.
Post by: digesterman on May 21, 2014, 09:17:12 AM
Are those heat pumps? I know some of the little diesels provide hot water too for heat in the winter.
Post by: TomC on May 21, 2014, 10:51:21 AM
With all due respect to Fast Fred, I can tell you from experience that sometimes the bottom line of burning a bit of fuel isn't the only cost. While the bottom line on a Diesel engine powered APU maybe a bit more then battery powered, you simply cannot keep a truck sleeper (which typically is not insulated that well) cool for much more then a day before battery charging is necessary. Then you're running the big noise maker.
I was a furniture mover which meant layovers many times over the weekend. I couldn't have imagined having battery powered A/C that required starting the big engine for a couple hours everyday. You can make that APU just about silent running-especially in a typically noisy truck stop.
Running the APU is a complete kit-like the one from ThermoKing and is totally covered by their warranty and multiple service outlets. Cobbling something together on your own-you just don't have the time on the road to repair it if something goes wrong.
DC powered A/C's are about twice as expensive as AC powered. Believe me when I say, you'll be very happy with the Diesel powered APU over batteries. Besides, the Kubota engines can go well over 20,000hrs before rebuild. Good luck, TomC
Post by: Grumpy4215 on May 21, 2014, 03:29:29 PM
New to bno tried the batt operated ac in my IH 4 axle with 120 inch sleeper
Wound up going to noise maker worked much better overall
Wound up here because insanity struck agin and now have pd4107 1053
Post by: FAST FRED on May 22, 2014, 07:09:45 AM
No question they are built JUST for an overnight , if your camping for days on end a noisemaker is the only choice.
Post by: jackhartjr on May 22, 2014, 09:53:09 PM
Hi folks, thanks for the discussion! In my operation I leave Thomasville, NC Sunday, drive to Florida and sleep about 10 hours, unload furniture during the DAT, maybe overnight and come home and get another load and do it again! So I am pretty much sleeping at night and driving during the day! I don't expect this to change! So I think this will work for me! There will be times that it gets down to 10 1/2 volts and shuts down! Hopefully it will be cool enough to sleep, or I run the engine! In that case I did save 10 hours idling!
To the guy that turned me on to Taylor & Crowr, Fort Myers, FL, thank you! I picked up 10 of the batteries today, they are blems, and paid $916.00 as opposed to $2,500.00 plus! I owe you big!
Thanks again folks!
Jack
Post by: eagle19952 on May 22, 2014, 11:32:39 PM
I am a bit surprised they had 10 on hand but good for you !!
They really are accommodating, good people all round. If I ever need a backhaul to Thomasville, NC I'll be sure and look you up  ;)
IF you ever need inverter work done I got a good contact in Bradenton.
PS. I forgot to add the 6.8 sales tax when I posted the price I paid I guess I got a better deal   :)   glad it worked out.
did they load test the batteries for you ?
