TOPICS => THE BOARD => Topic started by: BirdBus on September 11, 2017, 09:15:06 AM
Title: Fuel pickup issue
Post by: BirdBus on September 11, 2017, 09:15:06 AM
After weeks of wrenching, rebuilding the fuel pump, blowing out fuel lines, changing all filters, rebuilding the water separator, and breaking the pump key I've narrowed my fuel issue down to the tank, specifically the pickup tube down in the tank. I've removed the door and disconnected the intake line (larger fuel line) and ran fuel through it. The absolute last option was a clogged tank line, supposed I should have started there instead on going from back to front.
The pickup tube is clogged. Any tips on what to use to run down 3' into the tube? Pipe cleaner type of thing?
The bracket is welded on so removal is currently not an option. Pics to come. Attached is a basic example, although I can't remove mine, YET
Title: Re: Fuel pickup issue
Post by: uncle ned on September 11, 2017, 10:41:55 AM
If the pickup is clogged it is probably time to remove the tank for a good cleaning also.
Speaking from experience.
uncle ned
Post by: Templar52 on September 11, 2017, 10:35:29 PM
Try to introduce one of thoses mini wire camera inside the fuel tank. Of course ,you will have to empty the tank first. If it seem clean around the sucking aera at the botom end of the tube,the problem should be somewere else. But if you can see some debris,time to remoove the tank for a cleanup. If you emptied the fuel tank by the base plug,check if some debris are comming out of the tank. You can also try to run the bus with an auxiliary fuel tank and check if the engine is running strong and steady. That will indicated you the conditions of the fuel lines.
Good luck
Post by: BirdBus on September 12, 2017, 10:30:08 AM
That was my conclusion. The bus is able to run from a temporary fuel tank. I'm for sure the pickup is clogged, I even tried to blow into it with an obvious I was able to run compressed air but I had to crank up the pressure to 60 psi before I even got any bubbling.
My options are:
1- Remove the tank and clean
2- Drill a new pickup area and run a new line
3- clean out the existing tube with some stranded wire/ ground wire/ pipe cleaner of sort.
Either way, I think I'm going to drain the tank and let the rest run from the drain plug.
Any tips on removing the tank. It seems straight forward, just big as hell.
J
Post by: pd41044039 on September 12, 2017, 05:06:28 PM
My gut says the clog is either at the bottom of the tube or more likely, inside that elbow.  I would remove the barb & look there for accumulated bits of who knows what.  I think if it was at the bottom of the tube, it would have blown out way before 60lbs of air.
BTW, the tube may be too long to get out while the tank is installed, but look inside the bus & see if there is a cabinet or something above the fitting where you can drill an access with a hole saw to remove the pickup & put a removable patch in the cabinet or bus floor afterward.  You might have to do this again one day.
Post by: Uncle Augie on September 13, 2017, 01:33:14 PM
Usually there is a screen that keeps any large debris from entering the line, it sounds like there is corrosion on this screen, possibly because we let out buses sit and you end up with water in your tank from condensation.
Post by: buswarrior on September 14, 2017, 06:15:15 PM
Do the simple stuff first...
Why pull the tank when you don't need to?
Get that fuel pick-up cleared out, get a camera into that tank and make some decisions based on real observations.
With the prices of a computer video chat camera, one of those fancy things from the auto shop, or accessories for cell phones...if a busnut can't afford a camera suitable for shoving into the fuel neck, they can't afford a coach?
Somewhere in the archives, this board or BCM, I wrote up the tricks for pulling an MCI tank, it has a bump in the bottom, it has to go up, as well as out, and it is already against the ceiling of the bay...
Use the search, and link it here for the masses.
Post by: ibjj45 on September 15, 2017, 05:49:35 PM
Hey Birdbus, if you decide you can use a 5.5 mm o.d., 6 LED, USB camera (jpeg) that looks straight ahead, I'll loan you mine, if you pay shipping both ways. It's new (used once) and has a 30 inch (770 mm) reach. ibjj2@sbcglobal.net , 956-421-2589 Harlingen, Texas    ibjj
Post by: BirdBus on September 19, 2017, 08:19:16 AM
Welp, I am definitely opposed to removing that beast. I purchased a few pipe cleaners and drained the tank. The first one just bent and wouldn't shove in, the second on was a spring core and was able to clean the top but it got stuck half way down and broke  >:(  Now That line is surely clogged by gunk and a pipe cleaner. Fuk me
My next option is to grind the damn bracket off OR just drill a new pick-up line somewhere. The return line is doing its job so I may just find some after market pickup tube and drill the appropriate hole size. I'm indifferent.
For now she sits in the driveway sucking air
Post by: Templar52 on September 19, 2017, 08:55:37 AM
Try to remove  the fuel pick up by cutting it smal length at a time. That way you will be certain that it was the problem. Tell us what you have over that fuel line inside your bus . I dont think that it is a good idea to drill a hole to install a new fuel line.
You better drill a hole in your floor and have a permanent way to get to your fuel line. The real problem here is to know what material is cloging your pipe. If there is some more of thoses debries inside the tank.....the problem will come back soon.
Whent you drain your tank did you see someting coming out of the tank. If you enter your finger,can you toutch some debris ?
I think that you should try to have a tiny camera and inspect the tank by the drain hole.
That is my opignon
Post by: BirdBus on September 21, 2017, 10:40:02 AM
I'm going to take uncle Ned's advice and remove the tank and get that thing cleaned out thoroughly. I figure if there is enough gunk to clog it, I'm only going to delay my problem and end up cussing on the side of the road.
I have a friend with an engine hoist/ shop crane that is kind enough to donate for the weekend.
I still have the problem of the pickup tube being clogged in there. Once removed I can safely grind the plate off, or use a hole bit larger than the tube and drill the intake line out; not sure which option to use yet. I will take pictures and post them in here for any future endeavors someone may have, I'm sure others have lean issues if nothing else running with clogged arteries from the 70s.
Regards,
J
Post by: badlybentmc7 on September 21, 2017, 02:22:04 PM
You are on the right road,If you  don't pull the tank and clean it or replace it with something new its going to come back to bite you where it hurts, Do it right the first time and no worries.This comes from my own mistake trying to get by.1 hard lesson on the side of the road 100 degree's on sunday will school you quick.Good luck and happy wrench turning  Troy.
Post by: Lee Bradley on September 22, 2017, 05:47:39 PM
BirdBus your bus has a fast fill system. See here http://www.emcowheaton.com/refueling-systems/bus/ (http://www.emcowheaton.com/refueling-systems/bus/). The two large vent lines support that system. The fitting to the large vent going down has a whistle in it that whistles from the air escaping while filling. The filler has an automatic shutoff that shuts off the fuel when the fuel reaches a set level and the whistling stops letting the operator know the tank is full.  I removed both large vent lines and sealed one opening and reduced the other to a 1/4" vent line.  I also removed the auto shutoff enabling me to put 10 or 20 gallons more fuel in the tank as the shutoff is two or three inches below the fill opening.
Post by: BirdBus on September 26, 2017, 08:34:04 AM
I see, hmm. Well I appreciate the info for sure, sometimes you think something is just normal and someone schools you; thanks. I was going to track down that top line and see how I should go about moving it/ removing it.
I thought it was so sort of heating, via hot air, for the fuel.
Anywho, I purchased a 1 Ton engine boom from HF and assembled that garbage yesterday. I plan to tackle this, this week or weekend. I will update with pictures!
Post by: BirdBus on October 02, 2017, 09:21:33 AM
Well, I decided to use two 20k lb straps I use to tie down my jeep; one around a tree and the other around the top part of the tank. I ratcheted down to around ~500 lbs. She didn't even budge!?  :-\
I'm thinking the tank is just stuck by friction on the bottom wood plate it sits upon. Is that accurate or is there something I'm missing, I don't want to crack that front bump area by using too much force. Is there something else preventing this thing from pulling out?
Post by: gomer on October 02, 2017, 04:06:01 PM
Just some thinking that you can take a floor jack and put a board on it and try to jack it up some and maybe you will break it loose or find something else that is holding it in. I pulled one and was able to  break it loose and with a come a long and removed it. Did find some stuff that held it in tho.
Post by: Lee Bradley on October 02, 2017, 04:55:05 PM
You have removed the tie down straps?
Post by: pd41044039 on October 02, 2017, 05:05:07 PM
first, I'm sure you already have, but release the strain on the straps.
I've not pulled an MCI tank, but I did pull my 4104 tank.
There were several (maybe 3 or 4 ) bands over the top and down the sides that  have studs on the end that go down through the channels that support the tank.  Once those were removed (left in place, just pushed up through the holes in the channel) the tank slid right out by hand.   If your bus it that way, you will need to jack & block it up high enough to slide under 'cause the bands are WAY under.
(4104 tank is about 4' "long"  by 3' "wide" x about 2' high as you face the side of the bus.)
Post by: Templar52 on October 02, 2017, 08:01:32 PM
Be absolutely sure that there is no more fuel in the tank.
It happened that someone think that the tank is emptied but she is not. Some debries block the drain and the tanks is not compely drained. It happend to me many years ago. A bib chunk of rust and gunk was bloked the drain hole and i remooved a 1/4 filled fuel tank. Instead of a 200 pounds tank it was a 400 pounds tank. Fortunely for me,i removed it from a new look bus from under with a big tank table.
Alain
Post by: BirdBus on October 03, 2017, 08:11:18 AM
I removed 1 strap across the front of the tank. I can't see anymore straps or don't think I can visually inspect the rest of the tank. I stick my light against the inside wall and do a one eye look. I can see the wall of the opposite bay down the 3" wide tunnel. I even crawled under the bus thinking I'd see some magical bolt poking through the forward wall or the bottom, Nada!
Yesterday, I was able to put the tank under tension and wiggle it back and forth with a short 2X4. It did not progress forward even an inch, so I am nearly certain something is still holding on, whether the boogie man or some holding clip.  :o
Edit: So I found Buswarrior's old post specifically describing this process! Here is what I missed, now I feel better!
Buswarrior:
There is one strap on top holding the tank, remove bolts on both ends.
Get the fuel line connections on the top up out of harm's way. Catching them while inflicting the removal violence will ruin your day further...
Remove all aux fuel tank connection hardware from bottom of tank from under the coach. The bottom must be completely cleared off, or it won't come out.
But... the coach was positioned for maximum fuel drain,and now you need it positioned for safe crawling and working underneath... best to be doing some big thinking about the space you have to work with and how you will be crafty...
Similarly, check all the venting attachments at the top to be sure they will not hang up as the tank is pulled free.
The aux tank connection points on the tank bottom still stick down and will catch the edge of the hole, the edge that you get to see AFTER the tank is out... You need a thin lift to drive in under the tank via the removed side panel so that the sticking down plate will ride up out of the hole. A piece of plywood, 1/4 or 3/8 thick, 6-8 inches wide and 2 feet long or so and driven in under the tank will help lever the low points over the edge.
I have to say, I'm real curious to find this AUX tank,  suppose I'll follow the lines, should be a fun little adventure  ::)
Post by: buswarrior on October 03, 2017, 04:45:01 PM
Good research!
If you have the aux tank, it is inside that big box in the baggae bay. It fills via gravity and venting through the pipes atached on the bottom of both the main tank and the aux.
If you don't have an aux tank, you still have the mounting point and a plate covering the aux tank connections, as all the main tanks were built the same.
It is getting this downward protrusion slightly raised via the plywood shim that every MCI owner needs.
A chain through the fill and other openings and a pick-up truck leaning GENTLY might also be of assistance...
Post by: BirdBus on October 04, 2017, 08:07:36 AM
I have the bus on blocks, so I crawled under there, and sure enough there is a shroud leading from the bottom of the tank back to the rear of the first luggage bay. It is only held by 6 bolts. The two up front and rear were just 1/2" tapped. The middle are nuts on a bolt and just spin without help, I suppose I'll have to grind those off and put new in later.
Here are some pics until I wiggle under there after work.
Post by: BirdBus on October 05, 2017, 06:01:47 PM
Finally pulled the fatty out after work today; after removing the bottom shroud and plate it basically slid right out. Now I can abuse it with the pressure washer and take it to the fab shop and have a new pick up tube made up!
Here are some pics for reference.
Post by: BirdBus on October 17, 2017, 08:54:06 AM
Because I have an abundance of vents, I decided to use one for a new pick-up tube. The original inlet from the factory is a copper tube 3/8" DIA. I used a boroscope to inspect the empty removed tank. The line extends through the first two baffles into the third, near the port for the aux tank. Basically a lot of line to clean out. Plus the bracket is not removable.
I cut out some 1/4" plate with the plasma cutter and drilled a ~3/4" hole to accept a fitting, then brazed in a coupler to accept the old 90 deg fitting and a new one. I soldiered 3/8" copper tube to a fitting to fit the female end.
At the same time I removed the rubber hose from the aux tank connection lines and cleaned out that assembly. What a PITA! BTW the lines are 1 3/8" hose. I had to order fuel filler hose from RockAuto.com
I didn't capture the new line inside the tank but here are some pictures from the mounting.
Post by: gomer on October 17, 2017, 02:18:52 PM
that is the way to do it!!  Looks good and now no more problems. Just a thought, While you have all that apart consider putting an electric pump in the system so IF and WHEN  you loose prime you can turn the pump on and it will be good to go!!    Many ways to install one too. My suggestion is the supply line install 2 tees and put shut off valves on them and you can isolate the pump when not needed. Also put a valve in between those on the main line and shut it off open the 2 valves and pump away and when it is primed open the main valve and shut the others off  GOOD TO GO    Hope you understand this  LOL  I cant draw on this  LOL
