Link 1
Link 2
Link 3
Link 4
Link 5
02/11/26 - 04:38 AM
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Help
Search
Login
Register
The Archives
BNO'S Home Page
DieselChat
BNO on Facebook
BNO Email Login Page
Home
Help
Search
Login
Register
The Archives
BNO'S Home Page
DieselChat
BNO on Facebook
BNO BBS - BNO's Bulletin Board System
TOPICS
THE BOARD
Throttle cable replacement on my 4104
« previous
next »
Print
Pages: [
1
2
Author
Topic: Throttle cable replacement on my 4104 (Read 5388 times)
zimtok
Guest
on:
August 17, 2015, 10:13:34 AM »
Has anyone replaced the throttle cable on a 4104?
I have already replaced the 1/8" cable inside the tube/casing once but it is starting to bind again. I was thinking I could replace the whole thing with a cable that comes with its own casing.
I want to keep it a mechanical cable. I don't want to go to an air throttle.
What cable, length, brand would be a good choice?
Logged
gomer
Member
Re: Throttle cable replacement on my 4104
Reply #1 on:
August 17, 2015, 10:44:22 PM »
for starters was the original housing and cable still there? Next the main problem is the housing from the engine to the underside at the axles. It usually either rusted or worn out as it is on a curve from under the coach to the engine. It is replaceable and a truck shop can fix you with one. On installing it take the end loose under the floor at the front drivers door and then the same at the engine. take the cable and have it cut to length and don't worry about too long as mine clamps on the cable at the engine. The other end will need the fitting for securing on some units. When preparing to install from the rear get a tube of synthetic grease and put it in the housing to start and grease the cable freely while installing it. Push it as far as you can and then if you have any problem have someone to help with a drill on slow speed and turn it and you push as it turns and keep greasing the cable all the way. It takes a little time so don't hurry lol and messy too.
Logged
Gomer
In God I Trust!
zimtok
Guest
Reply #2 on:
August 18, 2015, 09:15:58 AM »
Thanks Gomer,
It has the original type of casing, whether it is original or not is unknown.
The cable in it is NOT original.
I had done exactly what you explained about 3 years ago.
I bought a 1/8" cable from the local hardware store 45' long. Greasing it as I pushed it through all the way to the front without any problems. Clamped it at the front, clamped it at the back to the correct length, cut the extra off.
I can do this again, but I thought if someone had replaced it with a newer style of cable that would last longer and maybe work smoother with less effort it may be worth a look at.
Logged
gomer
Member
Reply #3 on:
August 18, 2015, 10:26:58 AM »
I know what you mean and other than installing an air throttle your only option is keeping what you got.. If you have the original casing all you may need is from the firewall to the engine
Logged
Gomer
In God I Trust!
badlybentmc7
Member
Reply #4 on:
August 18, 2015, 02:13:41 PM »
the problems i ran into on my 04 was the old grease gunked tubing I used a brand new original cable none better in my opinion,made to last. Then ran brake tubing behind my cabinets all way to bulk head.drilled through
Logged
badlybentmc7
Member
Reply #5 on:
August 18, 2015, 02:17:45 PM »
I drove it 15 years after that whith no more problems,If i remember I had to use metric brake line to get a good tight fit that worked. Just an idea hope it helps
Logged
Brandon
Member
Portland, OR
Reply #6 on:
August 18, 2015, 03:06:17 PM »
I have taken apart and cleaned the curved section of my throttle cable on my 4512 (similar I think). That was where I was getting resistance that caused sticky throttle. Took it out, brake cleaned cable and tube, re-greased the cable and all is well. The rubber boot on the end is VERY important if you drive in dusty conditions apparently :-)
Nice easy system to work on in my opinion!
Logged
-Brandon
www.theghostbus.org
1955 TDH-4512 'The Ghost'
pd41044039
Member
Reply #7 on:
August 18, 2015, 05:47:24 PM »
The original center cable part is more like a speedo cable than anything else. There was a company in the Midwest (I think) some years ago that could supply it pretty inexpensively. I bet Luke can supply it too.
Logged
Jim Bob the BusNut
TedCalvert
Member
Reply #8 on:
August 19, 2015, 06:36:32 AM »
Remember to wash out the tube (housing) too. I took a pump-type garden sprayer and adapted fittings to the tube, then flushed kerosene through the tub. Lotsa gunk came out.
Logged
zimtok
Guest
Reply #9 on:
August 19, 2015, 09:36:30 AM »
Thanks for all the comments and suggestions.
I guess that I'll have to do a real good cleaning on it this time.
Last time (three years ago) I was in a hurry because I needed to get it back on the road. This time I'll make sure I have time to do a real good cleaning and maybe get the correct cable instead of just using a stock cable from a hardware store.
I have also noticed that my throttle lock cable casing is broken. If I pull on the throttle lock it will hold the throttle pedal just fine, but when I release it the cable is binding and preventing the throttle pedal from returning. That will be a project for another day. For now I have it disconnected at the throttle pedal.
Logged
TedCalvert
Member
Reply #10 on:
August 19, 2015, 09:51:05 PM »
Remember to lube it well when re-nstalling. Maybe a light grease, like Lubriplate.
Logged
JohnZ
Guest
Reply #11 on:
August 21, 2015, 09:40:57 AM »
I fought with the original cable on my '04 for 5 or 6 years. My biggest gripe was the engine took forever to idle down, making it hard to shift smoothly. I would pull the inner part, soak it and lube it. Sprayed cleaners and lubes into the housing. Finally it froze up damn near solid. I replaced it with a 40' cable for a MCI. Ran it through the bays. It took very little engineering to hook up the ends. It took a couple hours. Now the accelerator feels like a VW! Completely sealed and permanently lubed solution. My only regret was not doing it 5 years earlier.
Logged
luvrbus
Member
Reply #12 on:
August 21, 2015, 11:52:29 AM »
I would buy a Morse/Teleflex cable and be done with it,I don't fight those cables anymore they are too easy to replace, just about any decent hose supplier can make you one the correct length with the right ends
Logged
Member
Reply #13 on:
August 23, 2015, 08:31:57 AM »
If your 04 is the same as my 06 there are some cautions.
The cable run is NOT copper tubing it is very small brass PIPE!
So there is a difference in the inside diameter .
Also I would ONLY use the cable designed for the system , call LUKE .
Beware the wedges at the cable ends are easy to loose.
1/2 ATF 1/2 lacquer thinner pumped thru the old cable run will clean it out .
I prefer Teflon as the grease as it does not thicken below zero F.
Shifting will be fun again with a proper throttle response.
Logged
zimtok
Guest
Reply #14 on:
August 24, 2015, 08:35:55 AM »
Luke had the correct cable.
It was pulled out of another bus and was about 40' long.
1. sprayed brake cleaner into the tube and then blew it out with compressed air, repeating this several times.
2. removed the swivel ends and took them completely apart de-gunked all of the parts including the keepers.
3. installed the cable and greased it with lithium grease.
4. installed the keeper to hold the cable on the front end first and attached it to the throttle peddle.
5. installed the keeper to hold the cable on the rear and adjusted cable for proper peddle movement.
6. only when I was sure that the cable was at the correct length and adjusted properly did I cut off the excess at the rear of the bus.
It is still a little stiff but the throttle response to the peddle movement is MUCH better.
The old cable that I pulled out was just regular 1/8" cable from a hardware store, it had cable clamps at each end to hold it to the ends. At one time it moved very smoothly with little resistance, in fact better then the new cable I just installed. Lately it had begun to get stuck and bind, and made the peddle feel spongy. It also didn't pull the throttle at the engine all the way which made my top speed drop about 5 mph.
When I pulled it out it had some kinks in it. I think these kinks prevented the cable from returning properly and allowed the peddle to move a little before pulling on the throttle at the engine reducing the response of the RPM's in comparison to the peddle movement.
Thanks for all the words of advice, it sure helped guide me in this repair.
Logged
Print
Pages: [
1
2
« previous
next »
TOPICS
THE BOARD
