Next weekend I'll disconnect it in the engine compartment and remove the line. I'll be putting in an electric gauge in it's place.
Yeah, that line was my entire leak. I pulled the fitting and plugged it with a 1/8npt plug and added a gallon of 40wt. Initial idle oil pressure was 55psi. It dropped to 18 as everything warmed up. I ran it for about 40 minutes and no leaking. Got the air governor adjusted while I was at it. It shuts down at 105 and comes back on around 82 or so.
