Link 1
Link 2
Link 3
Link 4
Link 5
26/11/24 - 18:48 PM
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Help
Search
Login
Register
The Archives
BNO'S Home Page
DieselChat
BNO on Facebook
BNO Email Login Page
Home
Help
Search
Login
Register
The Archives
BNO'S Home Page
DieselChat
BNO on Facebook
BNO BBS - BNO's Bulletin Board System
TOPICS
THE BOARD
Detroit 2 stroke engine oil? Community knowledge:
« previous
next »
Print
Pages: [
1
2
3
Author
Topic: Detroit 2 stroke engine oil? Community knowledge: (Read 19505 times)
The Guy!
Member
MC8 1975 8V71 HT740
on:
May 30, 2016, 02:24:17 PM »
Hello Busnuts.
A more sophisticated list of oil sources appears to be needed, as the Detroit 2-stroke compatible oil is getting harder for some busnuts to find.
As the topic comes up every so often, here's a resource sticky thread that sits at the top of the Board.
What brand/name/model of oil?
Purchased from which vendor and geography?
With what part number/SKU?
And were there tricks the vendor employee needs to be coached through to locate the correct computer screen in the ordering system?
The sticky thread will allow for updates and commentary as the world evolves around us, and the Bossnut and I will keep it culled to keep the info as current as possible.
Last Edit: August 27, 2016, 02:30:40 PM by buswarrior
Logged
New project: MCI 102D3, 1995, Cat 3176b, Eaton Autoshift
Frozen, north of Toronto, Ontario
sledhead
Member
Re: Sources of engine oil? Community knowledge
Reply #1 on:
May 30, 2016, 05:23:21 PM »
this is what I use ,but not all walmarts have it
http://www.walmart.ca/en/ip/diesel-engine-oil-sae-40-189l/6000111967709
dave
Logged
dave,karen Home base huntsville ont canada
1990 mci 102c3 ddec ht740 350 hp...... sold
2000 featherlite vogue valtare 550 hp cat
joemc7ab
Member
Reply #2 on:
May 30, 2016, 10:40:46 PM »
I have been buying the same as Dave, and I believe Brian in Nova Scotia has also. Current price a couple of days ago when I was at Wallmart is 53 canuckies which translates to US 41 dollars for 5 us gallons. Me thinks thats a real deal for as long as it lasts. Come to think of it next time we are at Wallymart we are going home with a few more pails.
Cheapest maintenance is still a regular oil change.
Joe.
Logged
90 XL Country Coach 8v92DDEC-ATEC755cr Near Edmonton Alberta 780nine 8seven3 two 37
Member
Reply #3 on:
May 31, 2016, 07:08:10 AM »
IF it sez CF II and its sae 40 wt you're good to go.
Easiest to find seems to be 40 WT Shell Rotella which still carries the CFII in 40 wt.
Used to get 5 gal pails from the local NAPA or auto discount folks but the Rotella is cheaper at a big box store.
Multi weight oil , any brand ,is NOT OK .
Logged
luvrbus
Member
Reply #4 on:
May 31, 2016, 09:00:51 AM »
I use Delvac 1240 all the Exxon/ Mobil jobbers sell it or you can buy it at any Detroit dealer across the US
Logged
lostagain
Member
Reply #5 on:
May 31, 2016, 11:30:37 AM »
I used to get Petro-Canada's Dieseltonic 40W, CF2, .7% ash, made for Detroit 2 strokes.
Looking through their web site, I don't see it anymore.
It looks like all they have now is Duron single weight. The 40W, with an ash content of 1%, is recommended for a long list of engines, including the Detroit Diesel 2 strokes.
Any Petrocan bulk distributor will have it, or can order it.
JC
Logged
JC Alacoque
Blackie AB
1977 MC5C, DD 6V92TA, Allison HT 740
Lots of space to park for a visit
Shop to help fix your bus
AJ brink
Member
USAF retired PFE DC-8
Reply #6 on:
May 31, 2016, 08:10:52 PM »
Hi bus worrier I don't know your location, but I use DELO 40 and I usually buy it at Tractor Supply, many farm tractors use this oil and I really doubt it will be discontinued. It's a Mobil product and been around for many years. I run a 4104 6-71 4 valve head.
Logged
luvrbus
Member
Reply #7 on:
May 31, 2016, 08:33:49 PM »
Delo is not a Exxon/ Mobil product
Logged
Grumpy4215
Member
Reply #8 on:
June 01, 2016, 04:39:51 PM »
delo 40 get it at o"reilly or napa sacramento,ca.
grumpy(marshall)
916/919/1414
Logged
tim bookmiller
Member
Reply #9 on:
June 01, 2016, 05:50:06 PM »
Delo 100 40 wt O`Reilly pt #chv 100-40 $18.99 a gal.
Logged
RJ Long
Member
Vantaré Conversion "Miss Vivian"
Reply #10 on:
June 01, 2016, 08:30:44 PM »
Looking to find a source for your two-stroke Detroit's favorite oil? Try these links:
https://mobildelvac.com/en/distributor-locator
(For Mobile Delvac 1240)
http://www.deloperformance.com/choose-delo/marketer-locator.aspx
(For Chevron Delo 100)
http://rotella.shell.com/locator.html
(For Shell Rotella T)
http://www.citgolubes.com/#wheretobuy
(For Citgo Citgard 600)
For all of these sites, simply plug in the zip code wherever you happen to be and up will pop several choices. Most will be wholesalers, but don't let that stop you. If they say they don't sell to end-users, ask them for a retail dealer nearby who does. Don't take "no" for an answer easily, be politely persistent.
FWIW & HTH. . .
Logged
"Miss Vivian" 1992 Prevost XL Vantaré Conversion M1001907 8V92T/HT-755 (DDEC/ATEC)
"Toad" 2003 VW TDI Jetta Sportwagen
Based in Cheney, WA (When Home)
luvrbus
Member
Reply #11 on:
June 01, 2016, 09:48:48 PM »
Most Napa stores sells the Valoline Fleet Plus CF-2 in 5 gal pails also
Logged
Juni88126
Member
Reply #12 on:
June 02, 2016, 07:17:05 PM »
I found the Rotella t at the local tractor supply for 13.00 a gallon in 40 wt.
Logged
1966 pd4107-400
8v71n/4 speed
Aaron
Windsor, CO
Debo
Member
1981 MC9/8V-71N/4-Speed Spicer
Reply #13 on:
June 10, 2016, 01:53:18 PM »
I've always been able to locate Shell Rotella T 40 wt CFII oil in one gallon jugs at NAPA Auto Parts here in the states. If they don't have it at your particular store, they can usually get it in a day. NAPA Part #550019858
Logged
The Guy!
Member
MC8 1975 8V71 HT740
Re: Detroit 2 stroke engine oil? Community knowledge:
Reply #14 on:
August 27, 2016, 02:32:48 PM »
Changed the thread into a sticky note at the top of "The Board" and adjusted the title and edited for the long haul...
Logged
Print
Pages: [
1
2
3
« previous
next »
TOPICS
THE BOARD
