Shower Stalls - My Way!
by Fast Fred
Home depot sells a cheap 32-inch shower base for $50 or so. As I am building a 'convenient' conversion, all the plumbing is inside the coach, not in a bay and the shower isn't used many hours or many times a day.
Two plywood bulkheads, scribed nicely to the original roof, are fore and aft; the toilet room has a cutout to enter the shower and a shower curtain. The side facing the window has a clear plastic plexiglass water barrier and an insulated window shade can be rolled down to give privacy when needed. The front of the shower which faces the isle is a big box, with the top part being a hanging locker and the bottom part big bought drawers, the entire big box is mounted on HEAVY drawer slides, and locks in place.
To use the shower, we slide the big box hanging locker and drawers into the isle, adjust water temperature and enter from inside. You have to reach out past the shower curtain to change water volume or temp, but this tiny inconvenience allows the water plumbing to stay in the easily heated bathroom.
The shower sump is a small inexpensive marine bilge pump, with the pickup sump drain in the center where the drain would be. There's a small stainless bowl, inset slightly, to give the pump a low point from which to suck draining water.
The shower sump pump drains into the sink so all there is to winterizing is to pour plumber's antifreeze in to the shower sump, operate the pump for a couple of seconds and the sink drains by gravity down to the holding tank.
As a precaution against too much exuberance while showering which would force water past the plexiglass, the side panel in the shower was taken down and the fiberglass insulation was replaced with 1 inch closed-cell foam insulation. The naugahide pulled off from the side panel easily and was repainted with a spray can of paint.
As with most things in "PLUS BUS", it took longer to think up how to modify what exists than to build, and the entire setup can be removed if needed.
There is a 120-volt heater with thermostat in the toilet area, so most times just closing the toilet door keeps everything from freezing. Leaving the toilet door open almost touches the fridge which allows the rear of the coach to be heated some when we're hooked into campground power and its not tooooo cold out.
About the Author: Fast Fred was born and raised in the Bronx, New York, in the early 40s. He graduated from the City College of NY with a degree in Industrial Arts. His career has been spent as a flyer - from the Navy, flying P2V-7 Neptunes, to commercial airliners and most everything else. During his airline career he built boats, sold marine heaters and refrigeration systems and kept technically abreast of most types of engines. Fred and his wife, Charlene, have been motor homing for about 10 years in everything from a 31' Wanderlodge, a 22' Superior and their current GMC 4106. Simple is everything to Fred. "Like Scotty of Startrek, I enjoy figuring out the manual and construction diagrams to see how little I can do to make our 06 as fully functional with as little work and as few dollars as possible". They split their time between Florida all winter and Connecticut all summer using the 06 as the world's biggest station wagon, mixed with a few camping trips throughout the year.
