The inevitable has happened: You've done your homework, you have your spouse on your side (maybe reluctantly) and it's time to get this new project started. Here, this massive pile of iron (a.k.a. bus) stands on your 50 foot driveway with a seemingly forlorn look about it, just waiting for the your TLC. (Think I'm kidding? Just wait until you get your project up and running). You'll be like a new father! Everyone will have to have a look and, as you near completion, only a privileged few will get to see the final result. Those that laughed, wondered about your mental stability or said that you can't do that, will never be able to fathom the personal satisfaction that you enjoy as you and you significant other half drive out off the driveway on your way to your first adventure!
Back to reality for the moment. Seats. If they are still there, remove them. See if you can find a sale for them. Remove the rear wash room (if it has one). Strip out all the inside paneling, so that the frame work is visible. Replace the floor panels if necessary. If they have a spongy feel in spots, there is a chance that there may be some rot. Floor underlayments are usually made of some form of plywood. By now you should have a good feel for what you are doing. Check the tubing (frame) for any problems that may need replacing. Clean it up and paint it with a rust inhibiting material. Remember - if you neglect something at this stage, it may come back to haunt you later.
By this time you have likely looked at your plans and now you're trying to visualize the end result. I would suggest that you draw the measurements on the floor. This will give some idea of how things will fit and you just might get that extra 6" you may want for a cabinet or wardrobe. It will allow you to position any appliance that may need an outside vent (water heater, fridge) so that you don't have to re-work the tubing for its installation.
Now is the time to put your plan into action and enjoy the fruits of your labour and imagination. On the odd day when you are out in the coach "dreaming" and don't feel like accomplishing anything, keep a block of wood and an old pail handy. Why, you ask? Drive a nail or two into the block, and kick the pail around occasionally, and your spouse, along with the neighbours will think you are slaving away!
