27/11/24 - 07:28 AM
Author Topic: 2000+ Miles Last Week  (Read 4088 times)
Offline Bill Gerrie
  • Member
  • Phone or email. I'd be glad to help. 905-873-8929
Re: 2000+ Miles Last Week
« Reply #30 on: March 05, 2012, 08:47:32 AM »
Scott
I forgot to mention what ever transmission you get you also need the correct flywheel. They all use a different one. I hope when they rebuilt your engine they put in the double lip crankshaft seal. No big deal if not as you can change it easily when you replace the flywheel. Just check the part number they used. Double lip is 8927749. Single lip is 5114335. Single lip number might update as my numbers for it are very old. Double lip is current.
Bill
1965 New Look GMC TDH5303 6V92TA DDECIV & V731 ATEC with Overdrive
Offline Brandon
  • Member
  • Portland, OR
    • The Ghost Bus Build Blog
« Reply #31 on: March 06, 2012, 12:12:10 AM »
RE: the wiper controls.
I just scored a couple of new ones off flea-bay for a SMOKIN' deal. Mine were also hissing.
I tore my old ones apart and found hard rubber bits and worn metal parts. No easy o-ring replacements in those. See if it is hissing out the vent (very small hole on back) or at the seam between the front and back half.
We have the same controls (I have the new-look maintenance manual as well as the one for my old look). Let's me find all sorts of compatible parts.
Take it easy!
-Brandon
www.theghostbus.org
1955 TDH-4512 'The Ghost'
Offline Scott Crosby
  • Member
  • 1961 GM 4516 - DD 6v71, Allison VH9, 4.125 Gear
    • Bus Grease Monkey
« Reply #32 on: March 06, 2012, 07:27:00 AM »
FYI those are the kind of tire tracks I think my bus leaves behind... Flywheel too.. Son of a $$$ch
BusGreaseMonkey.com  A private friendly online bus community.  Never be afraid to learn and share.  A positive atmosphere with easy uploading and features.
