23/11/24 - 06:07 AM
Author Topic: from DieselChat - 6V92 turbo oil leak  (Read 2008 times)
Offline buswarrior
  • The Guy!
  • Member
  • MC8 1975 8V71 HT740
« on: March 03, 2012, 06:47:57 PM »
from woody, a voice in the darkness of an empty DieselChat room asked last week:
woody: I have an MCI 8, with a 6V-92, turbo.  The turbo is leaking oil.  Can the seal be replaced or do I need to purchase a rebuild?  Thanks.
have at it, I hope woody is reading.
New project: MCI 102D3, 1995, Cat 3176b, Eaton Autoshift
Frozen, north of Toronto, Ontario
Offline luvrbus
  • Member
Re: from DieselChat - 6V92 turbo oil leak
« Reply #1 on: March 03, 2012, 06:58:33 PM »
For 600 bucks replace it the center section is probably bad also where is it leaking on the outside or inside ?
Offline joemc7ab
  • Member
« Reply #2 on: March 03, 2012, 07:35:17 PM »
I am with cliff, my turbo for 8v92 had play in the bearings and having it done by people that do it everyday makes sence. Dollar amount is about the figure  in the above post.
                        Joe
90 XL Country Coach 8v92DDEC-ATEC755cr        Near Edmonton Alberta 780nine 8seven3 two 37
sandy
  • Guest
« Reply #3 on: March 04, 2012, 11:40:05 AM »
Hey guys  I am rebuilding a 1968 Flxliner (flxable) Has a 6/92 DD  Allison tranney.... The only trip i have made from Newark N.J. to Houston Tx.   Oil Leak around where the Flywheel would go on Eng. Large pipe thd. on bottem Leaking there.   My First guess would be Seals on rear main??????? There are other things connected to the Eng.  Air comp. ? Hyd. pump. Power steering.   I would like to see other guesses Please....   Uesd 1 gal oil on trip Very little smoke if any. Thanks Sandy
Offline joemc7ab
  • Member
« Reply #4 on: March 04, 2012, 03:49:01 PM »
Sandy
    Any leakage from the compressor / altenator would remain on the outside of the housing.  If it leaks from the hole in the bottom of the housing it would mostlikely be the rear seal.
                                             Joe
sandy
  • Guest
« Reply #5 on: March 04, 2012, 07:02:25 PM »
Joe that was my first guess.... Other guesses are cams.    assories   so i wanted other openion.      Thanks again joe sandy
