27/11/24 - 08:39 AM
Author Topic: Valve Cover gasket  (Read 1281 times)
Offline rnmadventures
  • Member
Valve Cover gasket
« on: March 06, 2012, 01:01:36 AM »
I have called S&S twice trying to get a valve cover gasket and they have a hard time giving me an answer without a serial number. I may buy a wall cameral just so I can get the serial, but until then I was wondering is there an alternative to buying the gasket. I have considered using form-a-gasket until I can get a real gasket. Would that hurt anything?
BTW we area talking about a 8v71.
Mike & Rosemarie
PD4106-2626
JackConrad
  • Guest
Re: Valve Cover gasket
« Reply #1 on: March 06, 2012, 08:33:32 AM »
For an 8V71 valve cover gasket, I think the difference would be whether your valve cover is cast aluminum or stamped steel.  Jack
Offline luvrbus
  • Member
« Reply #2 on: March 06, 2012, 09:31:12 AM »
www.dieselpro.com  pick out the style cover and gaskets you need a stamped valve cover gasket will be under 10 bucks the newer style rubber for the cast cover 25 bucks have one shipped to your door
good luck
  • Member
« Reply #3 on: March 06, 2012, 11:02:54 AM »
Thanks guys. I found the gasket on the link Clifford, thanks. I am saving that link.
Mike & Rosemarie
PD4106-2626
