15/04/25 - 03:15 AM
Author Topic: Motor Oil for 671 Detroit Diesel  (Read 27560 times)
Offline 1951Bus
  • Member
  • Steve & Mary Heiser/Winter Haven, Florida
« on: November 09, 2012, 09:34:17 PM »
Confused about the correct engine oil to use in my 671 Detroit Diesel.  I purchased 6 gallons of 15/40 Rotella T Diesel oil.  I cannot find straight 40 weight.  Is it okay to use what I purchased?
Offline eagle19952
  • Member
  • Donald P H.
Re: Motor Oil for 671 Detroit Diesel
« Reply #1 on: November 09, 2012, 09:55:40 PM »
Best not too.
1978 Model 05 Eagle w/Torsilastic Suspension,8V71 NA, DDAllison on 24.5's 12kw Kubota.
Wants Paint :)
Previously owned by Wee Willie Ent.
Offline TedCalvert
  • Member
« Reply #2 on: November 09, 2012, 10:04:06 PM »
I think the book recommends straight 30 or 40 wt., depending on ambient temp.
dreamscape
  • Guest
« Reply #3 on: November 09, 2012, 10:05:31 PM »
NAPA might have it on the shelf. I saw some the other day here in Seal Rock OR.
You should use straight 40 wt.
Offline eagle19952
  • Member
  • Donald P H.
« Reply #4 on: November 09, 2012, 10:06:23 PM »
here's your choices.
Low ash  mono weights:
UNION 76 T5X Heavy Duty 40wt:
76 T5X Heavy Duty 40wt monograde motor oils SAE 30, 40 and 50 meet or exceed the performance requirements of API Service Categories CF-2 and CF, and also may be used in applications where API CD quality oils are specified/designed primarily for use in high-output, 2-stroke cycle diesel engines. They are particularly recommended for use in 2-stroke cycle diesel engines in transit buses and marine fleets running on low-sulfur diesel fuel.
TEXACO URSA® EXTRA DUTY
SAE 30, 40, 50
The SAE 30 and 40 grades are also specifically
recommended for use in two-stroke diesel engines
requiring highly effective control of wear and deposits.
Texaco Ursa Extra Duty oils:
• meet API Service Categories
— CF-2, CD-II1 (SAE 30, 40, 50)
— CF, CD1
• performance requirements of
— Allison C4 Fluids (SAE 30)
• comply with Detroit Diesel Corporation twostroke
engine recommendations, including the
0.85% ash maximum limit for Series 149 engines.
Sulfated Ash Rates:
Chevron Delo 100 40 WT = 0.76 (24% BELOW benchmark)
Exxon XD-3 40 WT = 0.80
TEXACO URSA EXTRA DUTY = 0.85
Citgo Mystik Premium Fleet Engine Oil 40 WT = 0.90
Shell Rotella 40T 40 WT = 1.00 (Shell Rotella 40T is borderline)
Delo 400 40 WT = 1.35 (35% OUT of TOLERANCE)
THIS I AM NOT  SURE ABOUT but i researched it any ways :
AMSOIL Synthetic 10W-30/SAE 30 Heavy Duty Diesel Oil (ACD)
AMSOIL ACD is recommended for diesel engines, gasoline engines and other applications that require any of the following worldwide specifications:
• API CI-4+/CH-4/SL, CF, CF-2
Reply Quote Notify
Wants Paint :)
Offline RJ Long
  • Member
  • Vantaré Conversion "Miss Vivian"
« Reply #5 on: November 09, 2012, 10:27:13 PM »
Steve -
Best to take the multi-weight back, it's not recommended.  ONLY straight 40wt.
Do you have an O'Reilly's nearby?  If so, Chevron Delo 100 is usually available overnight or w/in a couple of days.  Tell the parts guy to enter the following info into the computer:
Vendor Code: CHV  Part Number (SKU): 100-40-1
This will get you 1 gallon jugs.  3 gallons/case.  7 gallons needed for an oil/filter change.  Buy three cases and have some left over for touch up.
FWIW & HTH. . .
"Miss Vivian" 1992 Prevost XL Vantaré Conversion M1001907  8V92T/HT-755 (DDEC/ATEC)
"Toad" 2003 VW TDI Jetta Sportwagen
Based in Cheney, WA (When Home)
Offline luvrbus
  • Member
« Reply #6 on: November 09, 2012, 11:03:16 PM »
You live in FL any marina on the coast will have straight 40w any brand is ok
Offline buswarrior
  • The Guy!
  • Member
  • MC8 1975 8V71 HT740
« Reply #7 on: November 09, 2012, 11:51:04 PM »
Real life example:
I knew where my coach was being operated in its former life. It had multi-weight oil in it.
I got it with fresh oil, and ran it. Oil consumption was significant, as I have since learned, relative to the age of the engine.
After my own first oil change to straight 40 wt, oil consumption dropped WAY down.
Others have reported similar experiences over the years.
There are also technical reasons to do with proper bearing lubrication with the high loading of the bearings relative to a 4 stroke. In layman's terms, the multi-weight won't stay in the bearing and do the job like a heavier oil will.
For busnut use, run the 40wt, and install whatever engine pre-heat system you have to, to compensate for cold weather starting.
I confidently run 40wt all year 'round and live up here in the nearer north, in relative terms...
New project: MCI 102D3, 1995, Cat 3176b, Eaton Autoshift
Frozen, north of Toronto, Ontario
Offline eagle19952
  • Member
  • Donald P H.
« Reply #8 on: November 09, 2012, 11:56:10 PM »
WEST MARINE< which is probably the highest price you will pay
DELO 100 Diesel Engine Oil - SAE 40, GA    6865349  222404436 In Stock $23.99< gallon
DELO 100 Diesel Engine Oil - SAE 40, 5 GA    6865356  222404448 In Stock $119.99< 5 gallon
call this number in tampa they are in orlando too.
 1-800-683-LUBE
Wants Paint :)
Offline Easy Street
  • Member
« Reply #9 on: November 10, 2012, 12:17:24 AM »
I just bought two 5 gallon pails of Rotella T 40wt from my Shell oil distributor 2 weeks ago.  It is still in their system, some dealers just don't stock it due to lack of demand. Try another dealer or use another quality brand of oil such as those previously mentioned.
Gil
PD3751-1287
NWGL Y578
Offline 57GMC
  • Member
  • We are close to Nashville TN if anyone needs help
« Reply #10 on: November 10, 2012, 03:10:47 PM »
I go to NAPA and order the Rotella T1 straight 40 weight and it meets the CF-2, CF for the 6-71.
Thanks
Steve
Offline Scott Crosby
  • Member
  • 1961 GM 4516 - DD 6v71, Allison VH9, 4.125 Gear
    • Bus Grease Monkey
« Reply #11 on: November 12, 2012, 07:30:27 AM »
That delo 100 at o'riley is only $13 and change per gallon for 40 wt.  They order it, and it comes in a day or two.  By far the best deal I've found.
BusGreaseMonkey.com  A private friendly online bus community.  Never be afraid to learn and share.  A positive atmosphere with easy uploading and features.
Offline Brandon
  • Member
  • Portland, OR
    • The Ghost Bus Build Blog
« Reply #12 on: November 12, 2012, 01:38:38 PM »
BTW West Marine will often price match Oreilies and other places if you play your cards right...
I bought a LOT of Delo100 40wt from them at OReilies prices (just sent them a screenshot of the web-page).
I run nothing but straight weight oils in the Detroit 2-stroke.
I get my info straight from Detroit:
http://brandon314.files.wordpress.com/2012/05/detroitdiesel_lube-oil-fuel-requirements.pdf
Skip to section 2.2
-Brandon
www.theghostbus.org
1955 TDH-4512 'The Ghost'
Offline 1951Bus
  • Member
« Reply #13 on: November 16, 2012, 07:45:06 PM »
Thanks everyone - will definitely take your advice!!
Offline wg4t
  • Member
« Reply #14 on: November 17, 2012, 07:01:08 AM »
A funny, Greyhound used SAE30 in all 71 Series DD engines also used it in the front & tag hubs.
Me, I ran SAE50 in my hot rod 8V-92, never a spun rear main.
Dave
MC7 20+ yrs
Foretravel w/ISM500 9+ yrs Gone
Too old to keep up.
Central Va.
