27/11/24 - 03:49 AM
Author Topic: Detroit 2 stroke engine oil? Community knowledge:  (Read 19517 times)
Offline windtrader
  • Member
  • '76 TMC/MCI MC8 8v71n, fully converted
Re: Detroit 2 stroke engine oil? Community knowledge:
« Reply #30 on: July 07, 2018, 12:53:32 AM »
Russ - Table 80 on page 115 shows Mobile Delvac 1240 and Shell Rotella 40 but missing Chevron Delo 100 although it shows something called Ursa Extra Duty SAE40. The ash limit shows as 1% and  CF-2.
Offline RJ Long
  • Member
  • VantarĂ© Conversion "Miss Vivian"
« Reply #31 on: September 10, 2018, 02:28:19 AM »
Oil Info Update -
To help you get "the right stuff" for your engine, here are some part numbers to help your ordering here in the USA:
Mobil Delvac 1240
719224968257 = UPC Code
#104056 = 4x1 gallon case
#102565 = 5 gallon pail
Detroit Diesel PowerGuard (From any Detroit Diesel dealer) (Private Labeled Mobil Delvac 1240)
#23512701 = 4x1 gallon case
#23512754 = 5 gallon pail
#23512702 = 55 gallon drum
Chevron Delo 100
#23968391454 = UPC Code
#100-40-1 = Gallon size at O'Reilly's (must also enter "CHV" in the vendor box.)
Shell Rotella T1
(If any of you can supply me with a manufacturer's part number and/or UPC code for 1 gallon jug/case, 5 gallon pail or 55 gallon drum, PLEASE send it to me via private message and I'll update this post with the information. TIA)
TIA,
RJ
"Miss Vivian" 1992 Prevost XL VantarĂ© Conversion M1001907  8V92T/HT-755 (DDEC/ATEC)
"Toad" 2003 VW TDI Jetta Sportwagen
Based in Cheney, WA (When Home)
Offline luvrbus
  • Member
« Reply #32 on: September 29, 2018, 09:05:10 AM »
Ursa was a Texaco brand from years back fwiw could be Chevron/Texaco is doing a repackaging deal,a Shell distributor told me Shell is dropping the CF/2 oil in 2020
Offline dtcerrato
  • Member
« Reply #33 on: September 29, 2018, 02:09:50 PM »
I guess we just need to buy a 55 gal drum next purchase so we don't need to worry where we're going to get it next time!
Dan & Sandy
North Central Florida
PD4104-129 since 1979
Toad: 2009 Jeep GC Limited 4X4 5.7L Hemi
Offline luvrbus
  • Member
« Reply #34 on: September 29, 2018, 02:21:43 PM »
There will always be some type oil out there that will work,the ash people worry theirs heads off about is gone already in the 15/40 oil
Offline eng0025
  • Member
« Reply #35 on: December 14, 2018, 04:51:29 PM »
i found  delo 100 40 weight oil in the phoenix area after 20 or so calls... im sure there are other compatible oils but its ran on that oil all along so i kept it the same. west marine had the 5 gallon pails for 95.00 dolla. thanks Jeff
1959 PD 4104 Winnipeg Canada
Offline tyreman
  • Member
« Reply #36 on: December 20, 2018, 02:48:09 PM »
I found 5 gal buckets at Tractor Supply for 49.99 with free shipping.
Traveller Heavy Duty Sae 40 Motor Oil 5 Gallon
SKU # 127699099
Offline chazmon3
  • Member
« Reply #37 on: December 21, 2018, 12:09:57 PM »
SKU # 127699099
Has anyone tried this oil for their 2 stroke engines?
1955 PD 4104 (Originally a Yosemite bus) Now 4 valve head, Jake brake, dual exhaust, DD3 brakes with all new and extra tanks in a dual circuit system. Chaz Sold to a new home 6/18/20
Offline luvrbus
  • Member
« Reply #38 on: December 21, 2018, 10:57:07 PM »
SKU # 127699099
Check the additives in the oil if meets the Detroit specs in your manual go for it ,if not pass on it
Offline Luckystrike
  • Member
« Reply #39 on: April 08, 2019, 09:52:19 PM »
I dont have a 2 stroke so im not super up on the specs required by detroit, but I came across brad penn oils many years ago when i was researching racing motorcycles and they are highly rated in the performance engine category. They have straight weight oils that are high in ZDDP, i'm not sure if this is a total match for Detroit Diesels but thought to pass it on to let others look into it, as i'm not sure many people have heard of them.
https://www.jegs.com/i/Glockner-Oil/461/009-7140/10002/-1
https://penngrade.com/
Offline chrome dome
  • Member
  • Dave 3/20/10Posts-469+
« Reply #40 on: July 08, 2019, 09:18:57 PM »
Travellers says 4 stroke in the specs sheet.
But the Phillips and Coastal both say for 2 strokes and meets all CF requirements.
https://petroleumservicecompany.com/phillips-66-t5x-heavy-duty-diesel-engine-oil-40w-5-gallon-pail/?gclid=EAIaIQobChMI98Ok8tOm4wIVFarsCh09jQMcEAQYAyABEgI_pfD_BwE
"Perfect Frequency "1979 MCI MC5CSaudi 6V-71,7067-7527 Spec230 644MT Allison
1998 Jeep TJ 4x4 Toed, Somewhere in the USA, Fulltiming
 Congressmen should wear uniforms, like NASCAR drivers, so we could identify their corporate sponsors
Offline Robert
  • Member
« Reply #42 on: April 05, 2020, 05:57:34 PM »
Here is what I use, so far stocked at Western State Oil Co.  Last time I purchased $41.06 for a case of 3 gal.
